I have a Bodine motor mounted to a metal box with the switch, speed control, and fuse receptacle. It takes the 1 1/4 inch long cylindrical glass fuses with metal ends. The motor data plate says it runs on 115 volts ac or dc, .85 amp, 1/25 HP, 5000 rpm, type nse - 11rg. What voltage and amperage fuse should I put in the fuse holder? The (corroded inside) one that came out of it is labeled 250 volt, MDL-1. Is there a table or chart or formula that will tell me also? Thanks.
