Been a wile since I posted here, But I am back and its great!
I recently landed a new free Baldor Standard E 3 ph motor to use with my grizzly mill ( on order now ).
Also just bought a 2HP single phase input 3 phase output VFD for a good price made by Bedford.
Any way, I been tinkering with it and testing it out, lots of options but one really confuses me.
Setup ( Motor = 4 pole 1740RPM 60hz 230V FLA = 5.6 amps 84% efficient )
Bedford VFD 2HP ( mostly original setup as manual, Other then sine wave carrier is at 15KHz - I don't think that effects any thing other then that annoying pitch I hear at slow speeds.
If any one is curious please take a peek, PDF format!
http://members.shaw.ca/H2O2/images/B801 Bedford user manual.pdf
Ok so I start her up and run it to the RPm range of about 1500RPM or so......Grab the shaft with glove and clamp down, I can literally stop the motor, then it doesn't want to come back up to speed, Is this motor not capable of being fed by a VFD?
I have the VFD setting on constant torque, but I am wondering what is going on exactly.......I know know much about VFD's so if some one takes a peek through the PDF and suggests some settings I am all yours!
I bought 2 VFD's to go onto my lathe and mill, basically both motors are identical, other then the FLA, one is 5.6 the other is 6, So I would really like this working.
Mind you I wont be turning the Hz down so far for the torque to be non existent, since the mill and lathe both have belt or gear adjustments - So if I want to run fast Ill put then mill or lathe down into the basement for RPM on the machine, then fine tune with the VFD........Right?
Thanks every one!
Thanks every one!
