RonRock
- Mar 18, 2012
- Underwood, IA
I have an old H-A-S static phase converter that I am currently running my Bridgeport with. I know it's not the best, but it works kinda.
When I power the phase converter on I can hear the relay "buzz" when I start up the BP the relay snaps and the contacts open. Seems to be working correctly. The relay would open dropping out the start capacitors.
But I wanted to check the voltage and be sure they were in the correct range, according to the HAS manual. I found that the voltage on the 3rd leg was much lower than the manual said it should be. So I pulled the caps to test them.
Here's what I found,
These are attached to the relay, so I believe that they are the start capacitors. They are Mallory 108-130MFD 330VAC. They measure 117 uF. (Can't make the symbol for some reason.) So does this reading indicate that the caps are all good? Or do I need to disconnect them and test each individually? Are they in series as I think?
There is also a separate capacitor that I think is the run cap. It is connected to terminals 2&3. 1&2 are line voltage. Seems odd to me that it is a 20MFD 500VAC cap. It shows 22.8uF. Seems to me that this one should be a larger capacitance size. But I didn't build the unit. I'm just guessing.
Not much to the unit. The relay is working, the only other item is the variable resistor and it seems to be working as well.
