intrepid
Cast Iron
- Aug 14, 2008
- Western Maryland
I bought a Rockford Milling machine that has the motor in the base. I need to determine the voltage because I'll be buying a phase converter. Is there any way to determine the voltage using some sort of meter without getting inside the motor wiring box? The motor is mounted in the base with the shaft and pulley facing the rear of the mill and the wiring box is just about against the left side. It appears impossible to get inside the motor box without removing the motor from the mill. Removing the motor from the mill looks like quite a bit of work! Just hoping to save some time. The motor is a Continental 1.5hp 3ph 220/440 volt 1730 rpm. Of course my hope is it is already wired 220volt.
thanks,
danny
thanks,
danny
