john mullen
- Feb 18, 2015
I have a milling machine I purchased from Harbor Freight. its a SKU40939 milling machine manufactured by Central Machine.. I need help to diagnose a problem with starting the machine. What Happened.. I was using the mill to set and tap a few holes.. I had the lid open and was jogging the start button to set the tap then I would turn the spindle by hand to tap the hole. then I set the reverse rotation switch and jogged the start button to run the tap back out. on the second hole attempt the start button would not do anything . Now the milling machine will not start or run. I reset the reversing switch to clockwise ,shut the top door so the run switch was on but nothing happens. I'm no electrician and know of no one who I can contact for help. getting no help from the customer service from where the machine was purchased. this milling machine was a purchase from Harbor Freight and there customer service is of no help. anyone hear have any suggestions . for what may have happened or know where I can find someone who can repair this machine...Thanks John Mullen
