bill1608
- Apr 17, 2008
- Central Illinois
I just purchased a new cheap Chinese VFD to try out. I also have a higher quality Japanese VFD. I compared both VFD's running the same 3hp 60hz 1750 rpm motor. The Japanese VFD ran the motor very smoothly and quiet, with only minor VFD noise from the motor. The cheap Chinese VFD ran the motor with torsional vibration at most speeds, but was pretty smooth at full speed. It caused more VFD motor noise at all speeds and was significantly noisier at some speeds. The motor being tested was sitting on the floor in a quiet area. I suspect that someone hooking up the cheap VFD to a motor on a heavy machine in a noisy area would not be able to notice the vibration or motor noise. The cheap VFD has fewer parameters to play with, like carrier frequency. The noise isn't a big deal to me, but I don't care for the vibration. It is a torsional vibration that feels like power interruptions, only not as severe. Is this noise and vibration typical of all cheap VFD's?
