UnusualFab
- Oct 27, 2011
- Pierson, MI
I'm new to VFD's so I just wanted to make sure that i'm getting the one that I need. I recently purchased a Bridgeport mill:
It's an older style with the pancake motor and I will be running it off single phase 220V. The motor is 3-phase and wired for 440V so i'll be rewiring that to 220V 3-phase.
Here's the motor ID plate:
I started a thread to get as much info as I could about the mill and someone suggested this VFD. It's for 1-phase 220V in/3-phase 220V out and for a 1hp motor. A few posts after that was posted someone mentioned getting a VFD good for 2hp. Do I need a higher horsepower VFD for what i'm running? I plan to wire up a plug (I have a 60 amp outlet for my TIG, can't use both at the same time, so I won't have to drop a new line), to the VFD, then directly to the motor. I'd like to run a setup like this to control the on/off and speed of the motor. I am ready to purchase a VFD but I just want to make sure I get the right one the first time.... Any help or suggestions are gladly appreciated!
