Depends on your goal.
If you are sealing up for EMI, so that your VFD powered military whatzit is not detectable via emissions, or not zapping your comm link, that's one thing.
If you need to meet agency emissions requirements, that's another.
If you just want to avoid getting complaints, yet another. That's going to be the usual goal. The agencies do not go looking for you, they rely on complaints.
Each need has its bandwidth. Most agency requirements go to 1 GHz. While an IGBT may have harmonics there, they are usually small. The real payload is going to be in the sub 100 or so MHz area, maybe 200. That is 2 or 3 m wavelengths, and does not require the same sort of attention as higher frequencies, not to mention that the most usual problem bands for complaints are in that area, likely the lower portion.
Any time you are worried about the radio impedance of a short length of wire, make it bigger, make it multiple, or best, make it wider. A wide thin strip is far better than a piece of 10 ga wire with more actual cross-section,
