LowEnergyParticle
Cast Iron
- Jul 26, 2004
- Beaumont, near Houston
I'm looking at some military surplus generators that are a pretty good deal. The snag is that their output is at 400 Hz, not 60 Hz. I've got a couple questions, if that's OK?
The prime movers on these generators are diesels. My guess is the system works something like this: the diesels are set to run at 2000 RPM and the generators are wound with 24 poles, creating 400 Hz voltage:
Output Frequency = Shaft RPMs * (Number of Poles / 2) * (1 minute / 60 seconds)
1) Does anyone know if this is how 400 Hz military generators actually work?
2) It seems like opening the generator case and rewiring coil connections to reduce the number of poles to 4, then changing the throttle feedback to run the diesel at 1800 RPM, might be a reasonable solution?
3) Does anyone know why the military uses some 400 Hz power?
I don't know much about this, so any information would be useful. Thanks very much!
Dave
Dave
