todd goff
Hot Rolled
- Feb 8, 2007
- south carolina
Well, I finally got the fellows gear shaper going after many headaches. I had a guy come out to the house and wire it that is an electrician at westinghouse. I figured out how to hook the wires from the motor to the speed control by calling a guy at ge motors in Indiana that was able to give me a wiring diagram for the motor. It is a four speed motor and it had four sets of terminal strips with 3 terminals on each strip. The motor wires were labeled, but over the years, some of the tags on the wires from the controller had fallen off, but some were still there luckily. I was able to use the motor diagram to figure out the numbering sequence on the terminal strips and connect the wires back to the motor on the machine and fire it up as there is no diagram for a ge motor controller as old as this one (1943). I fired the motor up and it tripped the breaker on one of the speeds. Here lately, I have been playing with the machine and cranking the motor up in the different speeds and can't seem to find the speed that wouldn't work. Anybody got any ideas on what's going on ; don't think the motor has fixed itself. Could it have been some trash inside the motor that came out when the motor ran some? Do know that the machine came from a shop that apparently had a foundry in it as I pulled the end off of the motor and it was full of foundry sand.
