Converting AC voltage to DC voltage?
gorrilla
Stainless
May 2, 2007
Central Texas, West and North of Austin
I have a little project for the shop at home. Trying to build a belt sander. I have a 115 V DC treadmill motor that I would like to use. This would facilitate varying the speed , making it much easier. The motor is 2.0 HP Continuous duty@ 115 VDC/1492 watts. I need to figure out how to convert straight 110 Volt AC current to something this motor can use. What are the groups suggestions?
You need to match that with a suitable dc speed controller. Simply rectifying ac would result in too high a voltage because 115-120v ac is the RMS value rather than the peak, which is nearly 50% higher.
EDIT: If you have the rest of the treadmill a fairly simple pulse generator circuit can be made to provide input, since all modern treadmill controllers are AFAIK designed for pulse controlled input rather than using a potentiometer like the older ones.
First this is stupid simple and very complicated as well.
Simple diodes will convert but you need a motor controller.
Look at the motor and determine just 2 things.
Operating voltage and maximum current.
Now search for a pre made motor controller rated for same voltage and slightly higher current and call it a day.
The assumption is since you are asking you may not have the skill set to make one and buying ready made is fast and easy and not that expensive.
Sent from my SAMSUNG-SGH-I337Z using Tapatalk
Maybe replace treadmill tread with sandpaper, and call it a day? :)
Many home shop references abound covering use of these motors with aftermarket/surplus controllers.
Just not many here on PM.
But then, I'm still trying to figure out how 'voltage' is a verb.
Yeah, I get that it's pressure, and an 'active' thing, but...
Chip
I thought those treadmill motors were way too slow for something like a sander. Maybe they have a gear reduction that can be removed?
easy. go to a thrift store and buy another treadmill . goodwill and habitat stores sell them for $25-$30 all day long.
if you make the thing belt driven, then you can get the speed where you want it with pulleys.
DC controller
I found a great company, Dart Electronics. Many sizes f AC to DC power supply, and speed controller.
A 2HP is around $200 on ebay $75+. I have several units and am very pleased with the units. Then even repair units, after you fry the thing. But thats a different story.
Most of the older controllers had a full wave bridge rectifier for the motor, and a triac based control on the AC side of the rectifier for speed adjustment (basically a more sophisticated version of a light dimmer). Some had speed feedback, some did not.
The stupid simplest "speed control" is a full wave rectifier setup, with a variac for AC amplitude control. You can get as complicated as you want after that.
I had a Dart on a DC motored machine, it was surprisingly cheap and surprisingly high performance. Eventually went 3phase on that one and don't look back but if I had a high quality DC motor in hand and a machine that needed it would likely go Dart again.
Actually that is not true. There is a reason why 115V DC motors are somewhat common. That reason is that you can JUST rectify the 115 VAC power directly from a wall socket to a pulsating DC and it should work. It is the RMS value of the Voltage that counts and if there are no filtering capacitors, then, even though the peak value of the rectified 115 VAC will be around 160 Volts, the RMS value will still be 115 V (DC).
If you add filtering capacitors, then they will try to charge up to that 160 Volt value and that will be too high for a 115 VDC motor. So, LEAVE THE FILTERING CAPACITORS OUT.
It is also easy to add a speed control to that pulsating DC in much the same manner that AC speed controls are made by switching the waveform on and off at various phase angles.
