Steve H. Graham
- Nov 6, 2007
- Miami
I just received a used 3-phase motor to replace the 1-phase job on a used lathe I just bought. The lathe is a Clausing 5936. The seller was supposed to send a 5914 with a 2 HP 3-phase motor, but he sent a 5936, which was 1.5 HP and 1-phase.
I hooked the motor up to my Hitachi VFD, without installing the motor in the lathe. It runs, but it makes a whistling sound that is extremely annoying. The whistling seems to drop as I go above 60 Hz.
Is it possible this could be caused by the VFD? The faceplate on this old motor is partially illegible, so I can't be positive about all the specs. I'm told it's a Reuland motor. It's dual voltage. I have it wired up with wires 1 & 7 as L1, wires 2 & 8 as L2, and wires 3 & 9 as L3. The remaining wires are capped together.
UPDATE: Solved it. I had to reprogram the VFD and increase the carrier frequency.
