Spindle Motor for K&T 2D rotary head mill needs repair/replace. Been lucky so this is first time faced with repair/renewal of a motor. I think I'll be unlikely to find a new or working Doerr 3/4 hp with proper case shape required for mounting in this mill. What kind of money am I looking at to have this Motor rewound, if I can find someone willing? The Motor has 9 wires for connecting to high or low voltage per the diagram, which I mention since it may impact cost of the work. I only plan to run it on 208v./3 phase, if it will run on that with overheating. I think the low voltage it is designed for is 220v/3 phase. I've never had this machine running, I bought it with the bad Motor.
