Hello,
Up until a hour ago I had a working green machine. Ive ran it for about five years. I started to help a friend with a painted billet grill that needed an aluminum weld. Basically I don't think it had a good enough ground and the machine stopped working barley after starting the arc. I know, my fault.
I have NO Output in tig or stick.
How can I move forward with a repair? Machine turns on and "idles" just fine. I have the cover off and see no physical issues. Pedal seems to work, as it triggers the HF (gapped to .008") and I get a few small strands of electricity jumping the gap between tungsten and work piece. It's probably the board or a capacitor, but I dont know how to tell. Is there a common "fuse" that will blow if too much feed back? I see no burned or damaged solder connections, everything looks fine, just dusty.
I've looked around a little online so far, but nothing totally related. Ive also read of two shops in Cali that may be able to help if it is the board. That could take weeks or even longer. What can I do in the meantime?
Any thoughts or info will be much appreciated!
Have a good weekend,
Jon
Jon
