So I was visiting my folks place over the weekend and decided to clean up the section of the workshop that has my grandfather's south bend lathe. My parents bought the place from my grandparents about 10 years ago. My grandfather developed alzheimers and didn't get a chance to really get his affairs in order (including the shop).
Anyway, I got the lathe pretty clean and checked all the oil points (still good). So I figured I would fire it up for a few seconds and make sure it would run before doing any more work/ purchasing accessories for it. The shop has 3 phase power, the lathe is a 3 phase (at least from the factory) south bend 14 1/2" lathe, and the plug has a 4 lug type of connector that is identical to the 3 phase 30 ton press (seen to the left of the lathe in one of the pictures).
Well, when the power supply was flipped on, there was a bad sounding hum, and then when the motor ran, the breaker tripped on the power supply. Obviously a bad sign, so we checked the panel and the fuses were fine, the power supply (which was labeled 3 phase) seemed fine. We eventually opened the door to the motor housing and that's when we read the tag on the motor and learned it was single phase!
So my question is, was the motor fried? When we tried to plug it into the 240v single phase receptacle, nothing happens. Maybe we fried something in the power supply? What's the procedure we should follow at this point? Thanks for any help.
Motor Tag (Clearly Single Phase)
Picture of the Work Area
Picture of two plugs (one is for a 3 phase press, the other is the single phase 240v lathe):
Picture of the receptacles:
