sae8425
- Mar 30, 2011
- western pa
Our property currently has a 15Kva pole transformer feeding a 100 Amp service. In years past this same transformer was also used to feed a barn and a mobile home (all long demolished).
Given the history of this property (ie. an old farmhouse that predates the 1936 Rural Electrification Act, a couple of Fanny Mae foreclosures, and at least one Sheriffs Repossession) I don’t know exactly how much of the electrical (or any other) system is ‘legal/approved’ in this property, and I don’t want to arouse any undue interest in the ‘status quo’ by the PoCo, or any other regulatory agency, by prematurely asking any questions. Sleeping dogs, etc.
And while I haven’t yet caused any neighborhood ‘light flickering or low voltage complaints’ (but give me time!) with my 30 HP RPC, I certainly am over-taxing that 15Kva transformer from time to time (but for only short bursts with plenty of lower demand time in between).
However, 100 Amps just doesn’t hack it when EVERY local Realtor that we have approached regarding resale modernizations tells us that local buyers are increasingly demanding electric heat & AC (and passing on properties with oil or propane). Can they all be wrong about this buyer mindset?
So a 200 Amp service would appear to be a prerequisite regarding marketing this house in say 5 years time.
Then there is my workshop (which is needed to modify various pieces of excavating type equipment to better cope with working on the many slopes and gullies on this pre Civil War farmstead).
So there’s a 200 Amp supply for the workshop as well.
And since there are many 5000 sq ft ‘McMansions’ in the local area that have 2 x 200 Amp residential electrical services, I’m not concerned about our request for a service upgrade being denied outright.
However, how concerned should I be regarding the PoCo insisting on ‘demand metering’?
In this thread:
http://www.practicalmachinist.com/v...ers-vfd/right-15-transformer-20hp-rpc-226630/
Froneck commented (in posting #11):
"Also be careful what you wish for when talking to the power company! If you want larger service they might put in a demand meter while boosting your amperage! What ever you do Do Not mention high amperage for short durations as needed while starting your 20 Hp RPC!!! You'll get a Demand Meter!!!"
And yet in this thread:
http://www.practicalmachinist.com/v...limiting-rush-amperage-motor-start-up-226948/
Jraef commented (in posting #13):
"Despite COUNTLESS anecdotes about avoiding "peak demand charges", the reality is that you are NOT charged for motor inrush currents in 99.999999% of locations.... If you have a residential service, they don't have any requirements, but your service capacity may be the limitation anyway."
Froneck (in a subsequent posting) gave me two examples of residential settings that he knows of where demand metering was required by the PoCo. So, at least sometimes, it does appear that residential users are required to have demand metering.
Now, two examples doesn't necessarily make demand metering a foregone conclusion, but is this a likely outcome of any request for 2 x 200 Amp services?
And if demand metering was put forward by the PoCo, is there any way that this requirement/stipulation could be effectively resisted/fought (especially prior to the service being installed and actual load readings being taken)?
In this thread:
