TJScharp
- Aug 6, 2011
- Alberta, Canada
I am aware that there are likely many threads I could research and so forth, but frankly I am blurry-eyed from researching.........
I have inherited a lathe from an uncle, and do not know by visual inspection how worn out it is, though signs of wear are showing.
This is a factor, since I do not want to drop the $1000-2000 dollars I have been quoted on a lathe whose function is questionable.
I had started down the rpc route but I really don't have the time to fiddle with the build, and would like some of the features of a drive.
The is the size of the motor of the lathe.
3 phase at 230V, 5HP (3.7 KW)
The primary functions I would like:
- ability to add an emergency stop foot pedal.
-convert single phase 220V to 3 phase
-I don't necessarily want to go with the cheapest unit out there, but $1000-2000 Canadian is a bit much....
The secondary features, or things I would see as a bonus:
- variable speed.
-a remote to mount at the lathe.
Thank you in advance for any and all help you could offer.
- variable speed.
