Drum Switch Wiring Help
Results 1 to 3 of 3
    Jun 2015
    CANADA
    Newfoundland and Labrador
    Default Drum Switch Wiring Help
    I bought a used Grizzly G1035 1 1/2 HP shaper from a guy. He had replaced the motor with a 2 HP Leeson (110402). The shaper has a drum switch to reverse the motor but he didn't have it wired properly and it only goes in reverse. I looked in the manual and it shows how to wire the switch but only to color wires for the original motor ( leeson has T numbers). There is no make or model on the switch (only rated power), so I can't look it up. There are 6 connection points on each side and I want to wire it for 220V. Taiwanese switch typical on these machines but very little info online.
    Jul 2014
    MI USA
    749
    189
    311
    A quick search online turns up the motor wiring diagram for the model you gave...
    Top right of the page, VIEW CONNECTION link
    LEESON Electric Corporation - www.leeson.com
    SAF Ω
    Jun 2001
    St Louis
    16,840
    1424
    2583
    Oh, you HAD TO mention that name..... That means this is closed due to hobby type machine being discussed.
  4. Likes Philabuster liked this post
