I don't think that switch will work for you. The label on the original unit shows all contacts are normally open. On the replacement unit the contacts are half normally open and half normally closed. And its likely the internal cams are for a different application.
I have no idea on who the manufacturer is, so I cant help with that, but there are other manufacturers, that you could obtain a replacement from. But to pick a replacement you need to know the motor type and current rating required.
Taking a stab at what you have, since you didn't specify is a two speed, single winding, reversible, 3Φ motor switch with 5 positions. A pretty specialized switch, and not that common, but available from other manufacturers. You would need the motor nameplate data and the connection diagram to be sure of what you have.
It's likely that your motor is whats called a Dahlander in Europe or Consequent-Pole in the USA. This type of motor is connected with the windings in different arrangements to achieve a different number of poles, in order to get different speeds.
Reference
Here is a sample drawing for a cam switch, that is as described above. From a German manufacturer Salzer
It would likely be a special order, so you would want to do your homework first. First comparing electrical suitability then mechanical fit. You can get it with an enclosure and different operators and a operating legend.
The catalog can be downloaded
HERE. Page 53 shows the part listing and page 72 shows the diagram.
Salzer USA Corp, Mesa, AZ
Phone: (480) 325-2690
Email:
[email protected]
Web:
Salzer Electric GmbH - Innovation. Technology. Quality.
SAF Ω
