whattheheld
- May 18, 2017
Hi all,
I have a VFD I was moving from running a vent to running a more essential conveyer that had had the VFD go out on it yesterday. The Original VFD had all the same nameplate info as the one I was trying to swap in, the only difference being the one I was trying to swap in required 240V and not 120V single phase.
Keep in mind these VFD's are in the same circuit on a 50A breaker. So in order to swap the 240V VFD into the place of the 120V VFD I had toconnect one 120V leg of a safety switch and another 120V leg of the safety switch to L1 and L2 on the VFD. The neutral in the safety switch was left untouched. I also connected ground to the safety switch. The safety switch has 15 amp fuses in it.
When I turned on power the VFD sparked, showed a Low voltage message and then died. Any ideas on what I did wrong? I keep going over everything in my head and I can't figure it out. Thanks in advance.
The 240V VFD is a GS1-20P5 Automation Direct Unit. The old 120V unit is a VFD004S11B Delta Electronics Unit.
-Conner
-Conner
