Hi I have been trying to use the Haas-kamp for a three phase transformer with 3 15amp 80 volts output . The A and C coil have a good 80V output but the B coil [centre coil] has only 6V on primary after working the formula and fitting two 22uf capacitor Also tried two 60uf and voltage went up to 30v on primary coil.I think the problem is that our single phase does not consist of two phases but of a live and neutral 240 volts , Can any one help , should I use a 500uf capacitor or....
