I recently just setup a pony start 30hp RPC for a Hardinge Conquest. Currently trying to track lines so I can make sure I only power the electronics with the 2 regular phases and not the manufactured phase. I think I have that mostly figured out but it looks like part of the 110v transformer would be wired by the third phase. Wondering if I need to change that or if it's OK because it's going through a transformer. It's a Fanuc OT system.
Was playing around with balancing the caps without load just to get things normalized. Can post some results later but for now I got them pretty close but they all seem a little high, like 245v to 250v. From my panel I have 244v coming in. Initially my third phase was 211v so I figured before I went on I should at least get them close.
Amp draw seems high currently and that dropped while I was adding caps. Currently I believe I have 300mf and 200mf in it.
Will be working on it some more today. I've read a bunch of threads already but is there anything I'm missing?
