CountryBoy19
Stainless
- Aug 14, 2012
- Bedford, IN
I don't have the model off-hand but my Toshiba VFD I got for my lathe does not have a function/setting for a coast stop. IE, I can't just set a function and have it coast to a stop, it always wants to do a controlled ramp-down stop at the time interval I set. ETA, this unit is quite old, I got it pretty cheap used. Trying to make it work to avoid the cost of a new unit (they get expensive once you go north of 3 hp).
There is a provision for a coast stop that must be as follows:
#1 FWD/RVS command is given & motor starts, #2 auxiliary input commanding coast-stop is triggered, #3 FWD/RVS command is trigger off and motor coasts to a stop. Sometime after the FWD/RVS command is triggered off the "aux coast-stop" command must also be triggered off before the motor will start again.
I'm using the drum-switch and control rod on my lathe to give the FWD/RVS commands to the VFD. There are several open terminals on the drum. The drum used to control the electro-mechanical brake, the main motor, and the coolant pump all from the drum switch. I'm now just controlling the brake and a single FWD & single RVS terminal for the inputs to the VFD. But as explained to me by the Toshiba tech, the aux input for the coast stop must be triggered on AFTER the motor has started and remain on until the FWD/RVS contactor is opened, and then the aux must be triggered back off BEFORE the FWD/RVS contactor is closed again. I don't think I can do this with the drum switch without involving a circuit.
My initial thought was a 2nd contactor that closes when either FWD or RVS is closed that charges a capacitor through a resistor. This will allow the cap to charge up after the motor is started, providing the aux signal, and then drain down when the motor is stopped essentially resetting back to the start point. I may have to play with resistor/capacitor sizing to get this to work right, I'm guessing my resistor will have to be quite a bit smaller than whatever internal resistor there is on the aux input line so that I get enough voltage to come through...
Am I on the right track?
