I am looking to retrofit a Toshiba S7 drive that came with my Bridgeport with Acer E-mill head. Seems like swapping out the existing VFD is the easiest solution to power up the mill. The existing drive has a braking resistor. Would this be needed for another drive?
I have narrowed it down to either an AC Tech SMVector drive or the TECO MA7200. What are the pluses or minuses for each one. I am simply looking for the easiest one to swap out from the existing Toshiba drive(I'm assuming similar functionality I guess). Price and ease of use is a consideration. The current drive is house already in an enclosure hanging off the mill.
How hard is it to retrofit one of these? Simply move the wires over? I'm hoping it isn't too complicated. I have all of the wiring diagrams for the current setup.
Thanks.
Thanks.
