383FormulaS
- Oct 2, 2011
- Panhandle of Texas
I have looked at alot of info on this forum and while I am much more educated than I was before I would still like some input. I am kinda on the fence on whether to go with a RPC or a VFD's for my set-up, I can see benefits with the VFD that I sure like. My problem is the room I built for my machines I wired for a RPC before understanding VFD's so with that said before I go any farther here is my machine list.
#1 Clausing Cochester 16spd Lathe 2spd 5/2.5HP 3ph 13/13.5amp continuous torque motor no clutch
#2 Birmingham 16spd mil 2spd 3HP 3ph 6/5.6amp motor
#3 Powermatic 20" bandsaw 1.5HP 3ph 5amp motor with model 600 blade welder that is wired in the machine 230v single phase (form the factory)
SO NOW WIRING
I have #4 wires running from a single phase 125 amp box to across the room which is 8FT wide to where the RPC controller would be and beside that is a 3phase 6 breaker box for distribution to the machines. If I go RPC I will just leave this be. If I go VFD I would change the 3 phase box out with a single phase box and power it with the #4 wires from the 125 amp box and have the VFD's at the machines. What I don't know is if my wires going out to the machines are big enough for the VFD's. I might of messed this one up as well with the RPC? Going out to the lathe which is about 15FT I ran #8 wire, to the mill I ran #12 wire which is 6 Ft away and #12 wire to a band saw that is about 10FT away. By what I have read on Hitachi web site I need #6 ran to the lathe to control the VFD and need # 10 ran to the mill. If I go the VFD route I would convert the band saw to single phase with a motor swap. I notice that the non-vector VFD shows #8 wire to be fine but the vector VFD shows #6 wire is needed. (Hitachi shows both #6 use 40amp breaker) vector and non-vector show the # 12 wire to the mill needs to be #10. Here are the VFD and the RPC's I have looked at.
VFD for lathe
X200-055LFU XVT2-75
WJ200-055LF PWV2-75
VFD for mill
X200-022NFU XVT2-30
WJ200-022SF PWV2-30-1
RPC For everything
American Rotary 15HP Rotary Phase Converter | Phase Converters | American Rotary
I might add that I am not much interested in building a RPC not that I don't think I could build one or that a home built one is bad. Im just saying If I go RPC I would like one that started with a push of a button and it have a soft start rating. I don't think I could build one that comes close to a soft start rating with out pony starting which I don't really want.
I value any and all suggestions and if something doesn't sound right please inform me I am not a electrician so my wiring could be far from right. Like I said Im not sure it is right even with an RPC after reading more info. I read somewhere that the wires going from the RPC to the different machines should all be sized the same as the biggest motor wire size which doesn't sound right to me. Because what if your biggest motor is 5HP and down the road you add a 7.5 you wouldn't want to rewire all of your machine just cause the 7.5 motor needs bigger wire. (RIGHT?)
Again this is how I have it #4 to the RPC controller #6 to the idler #6 to the 3phase breaker box, # 8 to the lathe #12 to the mill and # 12 to the band saw.
I'm not opposed to staying with my first thought of going RPC which might be the right choice with what I have and any future machines.
New member by the way if you couldn't already tell! LOL (First POST!)
SO NOW WIRING
VFD for lathe
X200-055LFU XVT2-75
WJ200-055LF PWV2-75
VFD for mill
X200-022NFU XVT2-30
RPC For everything
