imported_brian_m
Cast Iron
- Jun 25, 2006
- Oregon
I understand that having two 3 phase motors in operation at the same time somehow stabilizes the operation of an RPC. I have two individually switched pieces of equipment intermittently feeding from one RPC ( by that I mean either or both motors could be running at the same time ) and I recently added a transformer to power a third motor.
Does a transformer left permanently in the circuit act like an operating motor to help stabilize the RPC? Should I leave the transformer powered when the 3 phase circuit is in use or should I use a disconnect to remove it from the circuit?
