I've got a project coming up that I'm looking at using a VFD with closed loop vector control capabilities. I was looking at the Hitachi WJ200 drive, parts of the manual seem like its capable of it, but other parts seem like it needs an expansion card which is a future item.
Anyone have any experience with doing this on the Hitachi drive?
This is my first foray into closed loop vector. It is a really simple project, motor to a screw jack, speed controlled manually via a pot. Forward/reverse push button control with manual knob speed adjust, just dead simple. I would like the power ability at 0 speed given by the closed loop control. I think I could accomplish what I need to with sensorless vector, but would like the 0 speed ability.
I'm looking in the 2-5hp range with a DynaparHS35 encoder on the motor. This is a operate at 75Hz for 4 minutes, then slow down to .5Hz range for a few minutes. It will be a very minimal use item, but the slow speed is crucial to adjustments of the jack.
I've done about a half dozen different VFD's, but never a closed loop vector unit and haven't found a lot out there sub 1.5k$ units that advertise that they are capable.
If you have a suggestion as to a different drive to use that'd also be appreciated if the WJ200 isn't the right one for the job.
Ryan
Ryan
