pillageTHENburn
- May 31, 2017
Okay, I don't know if the motor is actually 100 years old but the lathe it is mounted on is!
The motor is 220V, 3HP, 3 Phase
At first I thought it would be easy to just "buy a VFD" but now that I'm actually looking I'm realizing there are a LOT more things to consider than I had originally thought... and now I'm getting overwhelmed with acronyms and options!
(I should mention that I will probably not ever use this lathe to it's full workload potential. This is my first lathe ever and I know it's probably overkill for a newbie like me.)
I have 220V single phase available right at the motor (this picture is before moving it to my place). I realize it's a big machine but to me 3hp seems like a lot for what I expect to ever do, is there a real danger in using a VFD that is "under powered"? The only reason I ask is that they seems to be cheaper as the HP demand goes down. If I'm not "pushing" the lathe will it not draw 3HP?
Does anyone have any advice or suggestions? Should I nix the VFD idea all together and just build myself a Rotary Frequency Controller? What about a static phase converter? While the lathe has gears to change speeds I like the idea of being able to infinitely control speed with a potentiometer.
I have lots more stupid questions where those came from!
Please help!
-Logan
Please help!
-Logan
