Newman109
- Sep 4, 2006
My question is at the end of the post.
Background:
Last summer, The control transformer burned up in my lathe. It damaged all of the contactors so that I had to replace all of the parts and most of the wiring in the electrical control box. After the repairs, the motor operates perfectly in both forward and reverse modes, although it runs too fast in jog mode. There are three contactors: forward, reverse and jog. Forward and reverse are operated with the forward and reverse lever into a rotary switch on the face of the lathe. Jog is operated by a button on the face of the control panel.
I've read that jogging uses full voltage (in this case 240 V, single phase). When I now jog, I have to engage the lowest of 8 speeds and I still get three or four turns of the chuck feeding full 240 V to the motor. Formerly, jog was much slower. I had to redesign the panel wiring myself since I had no schematic.
To address this issue, I've done some research and the term "Inching" is defined as providing lower power, say to a lathe motor, to provide small increments of turning. It would be a very simple matter with my present design to change the jog contactor so that it provides only 120 volts using line and neutral from the Acme control transformer output to the single phase motor.
I presume that the motor would run slower and in Inch (or Jog) mode the jog button would only be activated for an instant, less than say a half second.
My question is: would this damage the motor, given the very short duration of the power input for inching/jogging at the lower half-voltage?
Thanks in advance.
Background:
Thanks in advance.
