Hi, looking for some help regarding a pedestal drill head I picked up as scrap, I have a project in mind for it and would like to get it running.
Gearing is good just need to replace some bearings.
The machine in question is an Industrimaskiner (AB Stockholm) Type A59.
I would like to know if a can possible connect this to a single phase 240v to three phase 240v VFD.
I have tried to some research in regards to it but have not had much luck.
The info i have found usually relates to Arborgas that state 415v on the tags and these are not easily to run on a VFD if possible at all.
My tag however states the voltage at 380v so I am a little hopeful I can still connect it to a VFD.
I cannot replace the motor as it part of the head casting, rewinding is an option but I would rather not do so if possible.
Attached image of tag.
