Greetings all.
Purchased a cylinder hone for my engine shop that has a 3/4HP main motor and a 1/4 coolant motor. Input power is 220V 3phase for this machine.
Purchased a Hitachi WJ200-015SF and received it today. Looking at the output side, no confusion there. Looking at the input side, there are 3 terminals labeled L1/blank/N. My shop has single phase power and I'm planning to locate the VFD on the wall next to the machine taking over a previous dedicated 220V outlet. Am I correct in thinking that one "line" (e.g. Red) from the breaker panel will go to the "L1" terminal and the second "line" (e.g. black) will go to the "N" terminal, leaving the remaining white (panel neutral) unused? Or is this going to smoke the unit and I need a 120/240 transformer to take a single "line" up to 220 and use the white neutral?
