wrustle
Titanium
- Jun 8, 2006
- Massachusetts
I posted this in Cnc machining as well due to the fact a lot of the guys being home shops, but also wanted to get opinions from ones who are dealing with these types of concerns all the time.
Curious to know how you guys (mostly the home shop ones) power all your Cnc equipment.
I have 200 amp service in my house with 100 amps going directly to my shop. I currently have a 2 year old 30hp Des-Co Cnc rotary phase converter (up for sale real soon), but I am looking to upgrade due to some issues with my Ikegai Cnc Lathe.
It is a 15/20 hp machine and when ramping up it will flicker the lights in the shop (like a strobe effect) and knock out power to my Yam cnc lathe, and occasionally knock out power to my Haas VMC. The Des-Co converter is only rated for half of it's hp so the Ikegai when ramping up drawing 20hp really draws on the converter.
When I bought the Ikegai, I was told it was a 15hp machine which is why I bought the 30 hp phase converter. Had I known of the power issues due to it using 20hp to ramp up, I certainly would have gotten a bigger converter.
We have gotten by ok for the time being but it's at a point now where I need to have all the machines running most of the time in order to keep up with customer demand, and I just can't with things the way they are now.
I am looking at a Phase Perfect 20hp converter. I'm not sure though if that's big enough to run everything, but I believe someone in the past told me a 20hp Phase Perfect converter would have no problems starting a 20 hp machine.
So what are you guys powering your shops with?
Later,
Russ
Later,
Russ
