Chris Hall
Cast Iron
- Feb 28, 2013
- Greenfield, MA
I have a German pattern mill, a Zimmermann FV-5V, which is near-identical to the Czech-made TOS FNK-25, for those who might be familiar with that machine.
The head on my machine has numerous problems relating to the quill, quill lock, brake, and tool holding system that has led me of late to consider swapping in a new head onto the machine. In investigating that idea a bit, i found a company in Canada, HH Roberts, which makes replacement milling machine heads:
Replacement and upgrade milling machine heads for Bridgeport mills and Taiwan clones.
Their larger head is the closest fit to my mill (still a bit undersize at the mounting plate), but after looking at the mounting situation a bit more I am starting to wonder if this option is not quite so 'bolt-on' as it may appear.
In looking at that site though i noted with interest that they fit their replacement heads with a vector drive type of inverter run motor, rated for 7.5 hp, and max rpm of 7200. I like the simplicity of it and the higher rpm (my mill maxes at 4500 rpm) it offers is also attractive. So, an option I am now considering is to obtain another of the same type of mill (there's a few used ones in better condition and of more recent manufacture (1980s) available out of Germany), with a better situation with the quill, and more modern electrics, and then retrofit onto that a inverter motor similar to what HH Roberts uses. I consider this option worth looking at as rebuilding my current head is likely to cost the same or more.
Trouble is, when I go looking at motors and inverters, I find the whole thing decidedly opaque. I cannot find motors, for one thing, rated for 7200 rpm. Obviously they exist, but how to find?
My machine is running on 460v. 60hz service. Can anyone point me in the right direction in terms of variable speed inverter motors? Ideally I would like to obtain 6000~10,000 rpm at the spindle.
