Isacon VFD parameters for induction motor request
Status
Not open for further replies.
Ttrees
May 26, 2013
Ireland
Hello all
I have just received an Isacon VFD and cannot find info on programming it.
I have read some threads where these are used for spindles, but not induction motors.
After having only seen one thread, where someone has programmed one for an induction motor
the info on that thread leaves something to be desired.
The only other one I have come across is a man using one for his milling machine.
Type in Shawn Wagner into youtube to see it in action.
Unfortunately there is no info in the description or the comments, nor can I find him searching Google.
Hopefully someone has one of these units, and is using one for an induction motor.
Thanks in advance if you can help
Tomas in Ireland
Correct.
The isacon devices are a special version of the Huanyang. Many of the usual parameters are not available, and they are unsuitable for use with standard induction motors. Special purpose for certain high speed spindles.
Status
