I just picked up a nice used Acer 1440G lathe like this...
It will be used in my garage which provides only single phase power. I already have a Bridgeport mill in my garage, which is powered with a VFD that I wired up without any problems. My Bridgeport's VFD is wired so that it never experiences a zero load condition on its output which, from what I read, will quickly destroy a VFD. With the VFD output wired directly into the motor, this hasn't been a problem on my Bridgeport. Here is the bascis schematic I used on my Bridgeport:
single phase 220VAC from breaker box----> E-stop switch--->input to VFD----->VFD outputs 3 phase 220VAC---->Bridgeport 1-1/2hp motor.
But now I have this new machine and it has an integrated on/off switch built into the carriage/apron/saddle and also an integrated e-stop button. So offhand, I don't see how I can easily connect a VFD to the machine's power input without risking a zero load condition. Any ideas on how to approach this problem so that the lathe can be fully used the way it is intended?
