moonlight machine
- Nov 19, 2007
- marysville ohio
I had 244v feeding my RPC. voltage out was about the same, It was causing some issues with the control on my Miltronics lathe. Miltronics says 230v max. I used a buck/boost transformer on the power feed to the RPC. Got the voltage down to 223v 223v 224v so it worked good. Will the transformer use power when I am not using the phase converter?
