Grigg
Hot Rolled
- Jun 25, 2007
- Lexington, VA
Here's the situation, a friend just bought a really nice compressor and I'm to help him fiugure out how to run it:
-Quincy 370 compressor, currently 15HP 3 phase, just over 1000 RPM.
-Spec sheet for compressor says it can run as low as 400 RPM and would need a 7.5HP motor to do so.
-The 370 at low RPM will satisfy his air requirements.
-the Quincy starts unloaded until oil pressure builds, it's not a terribly hard starting compressor.
-No desire to run it at full speed and power or purchase the electrical components necessary to feed a true 15HP 3 phase load.
-Shop it's going in doesn't have 3 phase or a converter.
-Looking for a satisfactory and reasonably cheap solution,(likely excludes the Phase perfect and even a VFD)
Here's what I'm thinking,
Option 1. Remove 15HP motor from compressor, belt it with a pony motor to make simple rotary converter. Repower compressor with 10HP 3 phase motor and pulley size to suit the 400 RPM minimum.
Option 2 find 15 or 20HP idler motor for making phase converter. Keep existing 15HP motor on compressor but reduce pulley size to suit the minimum 400RPM.
Option 3 ??? and why is it a good one?
I like option 1 because wiring and components to be found are smaller and cheaper, downside is a little more work and uncertain if 15HP converter will run a 10 HP motor and pull a possible 7.5HP load.
I like option 2 because only modification to compressor is a smaller pulley and shorter belts, and motor is well oversized for it's new load. Downside is finding the larger idler motor for converter, and perhaps somewhat larger wire and breaker necessary to setup everything.
Any input on what size motors are really necessary in each case?
I'm not an electrician but do have a fair understanding of the different methods of and how to make a phase converter. Not real concerned about finding/purchasing an idler motor, in my experience they seem to turn up free or real cheap if you just let folks know you're looking for a big old 3 phase motor.
Thanks for any suggestions,
Grigg
Grigg
