Ober Gun Works
- Dec 31, 2005
- Riley Co, Kansas
I put together a 5hp RPC using the pattern that Jim Rozen has in the first thread, kicker motor turning the 3 phase motor to get it started and then turning on the power. Got it assembled and tested it by wiring into welder plug for the single phase feeding into it and the short lead that was on the motor coming out. Started the kicker motor and then used breaker to supply power to it and it started right up and ran fine with 120 volts coming out of the regular leads and 135 volts on the wild leg. I just wire nutted one input into one set of wires hooked to the short lead that had originally powered the motor and second input into another and left the last one like it was.
Had electrician come to wire up lathe and when he was finished wiring it in went to start RPC to start lathe it just hummed and would not start turning on its own. He changed wires around and tried it again, still would not start. Unhooked lathe and changed wires around again and could not get it to start. He claims that the RPC has to have a start capacitor to work but if so why did it start and run when I first wired it up to test? Any reasons that it would not work after wiring it up second time? I am not very electric savvy so not sure why it worked one time and not another. Thanks for your help and input on this.
