I am looking for a 240 x 400 V transformer for a European machine and have come upon an autotransformer with this basic spec, claimed to have a Y high voltage side. I can't find an official spec sheet for the transformer. The machine on the 400V side needs to have a neutral, which I assume means Y configured. Since this is an autotransformer, doesn't that mean that the LV side must also be Y configured? And that the center neutral can be (and in fact must be) connected, so that neutral on each side is the same potential? Since the 240 3Ph has a funky leg, won't this cause problems on the secondary, which will now also have a funky leg, WRT neutral?
A delta Y configured transformer seems like what I need, but 240 x 400 is not common. Curious if I can use the autotransformer.
