krap101
- Dec 2, 2013
- Antelope Valley
Hi,
I bought a lathe about 2 years ago and only recently started to set it up. I have a American Rotary AD20 which apparently puts out 3 phase delta, and the baldor is designed to be set up with 3 phase wye.
Here is the manual:
http://www.gain-control.com/Manuals/20H.pdf
where it gives this warning:
Baldor recommends not using “Grounded Leg Delta” transformer
power leads that may create ground loops and degrade system
performance. Instead, we recommend using a four wire Wye.
So, from what I understand, functionally, the difference is that the manufactured pole is 240 to ground vs 120 to ground. The American Rotary manual recommends a delta-wye transformer, which I'm assuming is the 3 phase transformer on their website that would be ~$1800.
Products
If everything I've assumed is correct, it probably isn't worth it to convert the supply to wye, so if operating the control off of delta will damage it, odds are the most cost effective way to get it to work would be to convert the lathe to work off of delta? I'm not that familiar, but I believe the previous owner or previous previous owner converted the vacuum tube control to this baldor control.
So, I guess my question is what my options are, and whether I can operate the lathe at lower power for minor projects until this is resolved. I'm not particularly looking forward to dropping a ton of money or to dive into what changes were made to the wiring and what would need to be done.
Thanks!
Danny
Here is the manual:
Products
Thanks!
Danny
