Hello everyone, I figured I had read enough that an RPC was fairly easy. Obviously not as I can't get it working. Before I hook up the start capacitors I want it starting manually with a rope. I spin the shaft, hit the contactor switch and the motor slows itself down to a stop. I tried spinning it in the opposite direction, same thing. I am using 6awg wiring for the power feeds and a size 4 Square D contactor. I measure 245v going to the motor.
I have the motor wired as follows:
L1 - 1,7,6,12
L2 - 2,8,4,10
L3 - 3,9,5,11
L1 and L2 have the power lines and L3 is the generated leg. Here are the pictures for the wiring and motor specs. Any help would be greatly appreciated.
L1 - 1,7,6,12
L2 - 2,8,4,10
L3 - 3,9,5,11
