Hey All,
I'm trying build myself a 2"x72" belt grinder. I managed to get a handful of 1.5HP 3-phase motors to use with a VFD for the grinder, but for some reason they're not playing nice with the VFD. I have multiple identical motors (Leeson) that came out of commercial treadmills. I was told that they work (for what that's worth).
The motors are 230V only (no high voltage) and have five lines coming out. P1 and P2 are marked to go to a thermostat (they're NC based on the multimeter). I left them disconnected for checking to verify the motors work. T1, T2, and T3 go to the three 3-phase lines based on the wiring label.
When connected through the VFD and powered on (should ramp up to 60Hz over 30 seconds), they ramp up to about 4.5Hz unsteadily and stop there. The rotation didn't seem smooth to me. I didn't leave the VFD on for an extended period for fear of hurting something. I tested multiple of these recently-acquired motors with the same result.
For now, the VFD that I'm using (2HP rated, TECO JNEV) is used to power a 2HP motor on my bandsaw with very similar specs. I reconnected the VFD to the bandsaw after this testing and verified that it still ramps that motor up to full speed smoothly.
I put a multimeter across the T1, T2, and T3 lines on the motor. All were open to ground, and there was about 2.0 ohms between any pair of the lines. So my impression is that the motors aren't bad.
Any thoughts on what the problem might be and what I can check?
Tyler
Tyler
