swellwelder
Stainless
- Sep 21, 2002
- Valley City, ND USA
Here's the set-up. I am in the process of installing a new DC drive on my EE1000. One of the pots I want to use is for the CSS(constant surface speed) This control pot has a rating of 50k, but the DC drive has a setting of only a 10k pot for speed control. So, is there any way to reduce the ohm value of the 50k pot so that the DC control thinks its a 10k pot?
Another question is the switching between the main speed control pot and this CSS pot. Would it be better to be using a switch that drops out one pot before the other replaces it electrically, or one that doesn't drop circuit A until circuit B is introduced? Seem like either way has its own problems, but I am no electrical engineer. I should mention that the DC control unit is almost exactly like a VFD except it only converts AC to DC, but not the next step of changing the current back to a frequency controlled AC The control is a Eurotherm brand, regenerative model.
Dale
Dale
