IQRaceworks
- Jun 18, 2010
- MISSOURI
So I'm getting ready to wire up my Quincy 325 air compressor with a 7.5hp single phase 220v motor on it. I wired up a 220v single phase outlet on the wall, coming off of a 50a circuit breaker in the breaker box. The 3-prong type 220v outlet has 2 hot wires, and 1 ground wire going to it....no neutral (or common).
Here is the problem. All of the 40a 7.5hp motor starter boxes I've seen have a 120v coil (powered by my pressure switch). The problem I'm running into is that in order to power the coil with 120v single phase, I need 1 hot wire and 1 neutral wire......which I don't have.
So, the way I see it...I have two options. 1. wire up a different 220v outlet box, one of the 4 prong receptacles with 2 hot wires, 1 ground, and 1 neutral wire. Then I can pull 120v power off of 1 hot wire, and 1 neutral wire.
2. I find a 40a motor starter box with a contactor that has a 220v coil. I've looked, but haven't had much luck.
Any other options? What as I missing??
