lin842
- Sep 27, 2008
- Richmond Va
Can anyone help me figure out why my motor starter wont work like it should? I have a ge 3OO line control that I bought form graingers and it as never worked since I got it. There were no directions in the package and the box had been opened. After I tried to get it going and it would not work like I thought it should I went back to them to see if they had another one to see if there would be directions in another box but that was the last one they had and that I had probably burned it up by hooking it up wrong.
This is possible but I would like to know what is burned up and get it to working. I have spent days looking all over the internet and everywhere I can think of to find directions of how to test this thin. I remember when I bought this thing and it would not work I go around it by just hooking the line voltage and the motor leg together at the top of the contactor effectively in my view bypassing the control.
If I hook the motor leg to the T1 and T2 terminals at the bottom of the starter it will not work unless I manually push the spring loaded button on the coil. And when I turn it loose the motor stops. I can hook the motor le wires to L1 and L2 and when the pressure switch on the compressor calls for pressure the compressor runs like it should but isn’t that bypassing the whole starter switch altogether?
