wrustle
Titanium
- Jun 8, 2006
- Massachusetts
If the brushes on my CNC Lathe DC motor are bad, would that cause problems with my spindle not coming up to speed, or drawing excess voltage from my RPC when trying to come up to speed? I had a problem with my RPC a couple weeks ago, and had to send back the panel with the capacitors in it to the manufacturer so they could replace what they figured were some bad ones. The unit was still under warranty so other than being down for a few days it wasn't too big a deal. They replaced all the capacitors in the panel and added a couple extra of the oblong ones to help with my low incoming voltage problem (226 coming in from the pole)at least that is what they told me it would help alleviate. So the panel comes back, get it all hooked up and everything runs fine, except my 15HP CNC Ikegai lathe still will not come up to speed, and as soon as I hit the spindle start button, I get a "Phase Loss" error on one of the VFD's I have hooked up to another gear head CNC lathe. I mentioned this problem in another thread "Spindle Not Getting Up To Speed" and it was mentioned that perhaps the brushes may be bad, and I just figured before I go and remoeve all the guards around the motor and try to get access for checking them, I would ask this question again. Could it be brushes? Is there some other reason why the spindle won't come up to speed? If I enter in S2500 RPM it will take about 15 seconds to get up to speed, and that is about the max it will go, even though I should be able to get 3150 RPM's. I don't use this lathe all that much but I know it will go that fast because I've had it running that fast before, I just thought this was tied in to my RPC problems, but now that the RPC is not the problem I must look else where. Anyone have any thoughts on where to start?
IKEGAI CNC LATHE 15HP
A-B-NO LOAD-224 AMPS-12 LOADED-224 AMPS-25
B-C-NO LOAD-232 AMPS-13 LOADED-230 AMPS-15
C-A-NO LOAD-224 AMPS-6 LOADED-214 AMPS-18
Best Regards,
Russ
Best Regards,
Russ
