docdesigns
- Jan 23, 2015
- Syracuse, NY
I am installing a new underground separate service into my home shop and have a question about the service entrance sizing of the neutral. It would be common place here to run a 3 wire aluminum direct burial cable consisting of 2-4/0 hots and 1-2/0 neutral for a 200 amp 240 volt service single phase. The main loads will be a 3 phase convertor running one 7.5hp CNC VMC and one 7.5hp CNC lathe.
I am wondering if running a full size neutral and using a triplex type direct burial 4/0 cable would be of benefit instead of the downsized neutral? The cost between the two is very little.
This distance is 225 feet from the utility pole with the transformer to the meter socket and main panel.
Thanks for any help.
