Testing the Teco L510 and this motor (also in thread below)
https://www.regalbeloit.com/Products/Catalog?model=056H17E5305
I know zip about VFD's...and am puzzled by what's going on.
On initial testing, motor would vibrate horrendously as it approached 20hz and the VFD would shut down from overcurrent error after about ten seconds. Somehow I decided to ramp up quickly to 60hz, and after getting past 50 hz or so, purred like a kitten up to 60 hz (did not overspeed test beyond 60 hz.).
What would cause the motor to run smoothly up to 20 hz., shake off the bench between 20-50 hz., and then run so smoothly at 50-60 hz. I didn't think it was even running?
Any ideas/suggestions on a parameter that I need to set?
