Thanks to all who post on this forum. I was able to select and install a vfd on my bridgeport by reading on here. I thought I was good to go when I started it, changed speeds, reversed motor and then shut it off But then I turned on the radio while it was running and it's all static So is this usual or did I miss something? I used a Teco jnev 101-h1. Input is 115 vac, output 230 vac 3phase. It's rated for 1HP the mill has a 1HP motor. I used shielded wire for the control circuit.
