Chip Chester
- Dec 13, 2007
- Central Ohio USA
At substantial risk of proving my ignorance, and suffering the inevitable public floggi... er, re-education, here are two 'conceptual' questions regarding home shop 3 phase issues:
Question 1. I understand the risks of using a VFD as a RFC substitute, and the virtual certainty of smoking it by using the connected machine's original electrical controls. (...connecting and disconnecting the load on the VFD while the VFD is powered up.) Could I minimize this risk by continuously running another 3-phase motor as a full-time load, just spinning away in a corner turning a fan blade, or nothing? (So, instead of the load on the VFD vanishing when I switch off the mill, it just decreases from, say, 2 hp to 1/3 hp.) (Note: I know I'm not utilizing the major benefits of a VFD in this plan... I will later, but not for about a year, schedule-wise.)
Question 2. Instead of constructing and load-balancing a RPC, can I just use my 3 hp 3-phase motor as a true generator, powered by a 3-or-so-hp single phase motor? (So the only connection between the motor and generator would be a belt and a ground wire.)
That's them. And yes, it's possible that I overlooked oft-repeated answers to these questions -- if so, I apologize in advance. And I realize that there is an efficiency penalty in each scenario. My hobby use of the machines is currently low enough that electrical efficiency (in dollars) is a non-issue. The loads I place on them are nowhere near their mechanical and electrical limits, either. And for discussion purposes, the current inventory of 3-phase machines is: 2 hp Cincy Toolmaster mill with (3-phase) power feeds, 1.5 hp Clausing lathe with no additional feed motors, and .5 hp Delta shaper.
Thanks, and let the thrashing begin.
Chip
Chip
